08-30-2007 12:07 PM - edited 03-03-2019 06:32 PM
Hi - Am looking for technical information related to deploying and configuring VRFs in a network. Also, basic info on VRF tables,L3 associations., etc.
KC
08-30-2007 12:51 PM
If you are asking about VRF Lite, then VRF lite converts the router into multiple virtual routers each one with its separated routing table (called VRF table), interfaces and routing protocols.
Router(config)# ip vrf customer
Router(config-vrf)# rd 1:1
Router(config-vrf)# route-target both 1:1
Router(config)# interface fastEthernet 0.1
Router(config-subif)# ip vrf forwarding customer
Note VRF-Lite does not include the Provider Edge MPLS functionality. More specifically, MPLS label switching and MPLS control plane are not supported in the VRF-Lite implementation, if you are looking about this please let me know.
HTH,
Mohammed Mahmoud.
08-31-2007 07:58 AM
Thx,MM. Good info. Here's the setup..have a 6509-E and a 4948-G switch. Trying to build VRF instances between the two.
4948-G:
ip vrf vrf-100
rd 65001:100
route-target export 65001:100
route-target import 65000:100
6509-E:
ip vrf vrf-max
rd 65000:100
route-target export 65000:100
route-target import 65001:100
Associated vrf-100 to VLAN100 & VLAN10 on the 4948. There's E-BGP between the 6509-E(AS65000)and the 4948-G(AS65001).
Created an address-family on the 4948(ipv4 vrf vrf-100)with e-bgp neighbor to 6509, included networks for VLAN10 and VLAN100. Same on the 6509(address-family ipv4 vrf vrf-max) with e-bgp to the 4948 switch.
here's the problem, when I do a show ip route vrf vrf-100 on the 4948-G switch, it doesn't list the routes on the 6509 switch. Pls advise if something's missing..
KC
08-31-2007 10:17 AM
Can you please paste your full BGP configuration from both sides, it should be something like this:
router bgp
neighbor
network
HTH,
Mohammed Mahmoud.
08-31-2007 10:23 AM
6509E---
router bgp 65000
no synchronization
bgp log-neighbor-changes
neighbor 192.168.110.190 remote-as 65001
no auto-summary
neighbor 192.168.110.190 activate
no auto-summary
no synchronization
network 192.168.119.224 mask 255.255.255.248
exit-address-family
4948G---
router bgp 65001
no synchronization
bgp router-id 204.155.112.47
neighbor 192.168.110.189 remote-as 65000
no auto-summary
address-family ipv4 vrf vrf-100
neighbor 192.168.110.189 activate
no auto-summary
no synchronization
network 10.193.10.0 mask 255.255.255.0
network 10.193.100.0 mask 255.255.255.0
exit-address-family
08-31-2007 10:45 AM
The configuration is fine, can you please post the relative show ip bgp summary, show ip bgp, and show ip route vrf <>.
HTH,
Mohammed Mahmoud.
08-31-2007 11:42 AM
08-31-2007 12:22 PM
No i meant the following:
show ip bgp vpnv4 vrf <> summary
HTH,
Mohammed Mahmoud.
09-04-2007 12:56 PM
6509#sh ip bgp vpnv4 vrf vrf-max summary
BGP router identifier 204.155.112.43, local AS number 65000
BGP table version is 4, main routing table version 4
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
192.168.110.190 4 65001 0 0 0 0 0 never Idle
4948-G#sh ip bgp vpnv4 vrf vrf-100 summary
BGP router identifier 204.155.112.47, local AS number 65001
BGP table version is 9, main routing table version 9
2 network entries using 274 bytes of memory
2 path entries using 136 bytes of memory
2/1 BGP path/bestpath attribute entries using 216 bytes of memory
1 BGP extended community entries using 40 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 666 total bytes of memory
BGP activity 8/6 prefixes, 9/7 paths, scan interval 15 secs
192.168.110.189 4 65000 0 0 0 0 0 never Idle
09-04-2007 01:02 PM
Now its obvious, BGP is idle, please make sure that you can ping the opposite interfaces within the respective VRFs, and if you are peering with loopback please make sure that you have appropriate routes and that you can ping your peer ip.
HTH,
Mohammed Mahmoud.
09-04-2007 01:24 PM
Thx, MM. Will give it a try...the idle state missed me. Was going with the global neighbor established state but overlooked the BGP state via the VRFs.
