DCHP for VPN users not working
Aug 30th, 2007
ASA 5520 running 8.0(2), can't get asa to pass DHCP request to internal DHCP server. I've done serveral capture on inside interface and never see any request being forwarded. We normally use the microsoft vpn client, but I've tested with cisco client as well with same results. It is assigned at the group policy and the connection proffile to use DHCP, server and scope needed is identified. Please Help.....
MODE_CFG: Received request for DHCP hostname for DDNS is: x.x.x.x!
[IKEv1 DEBUG]: Group = xxxxx, Username = xxxxxxxx, IP = x.x.x.x, IKE received response of type [] to a request from the IP address utility
[IKEv1]: Group = xxxx, Username = xxxxxxxxx, IP = x.x.x.x, Cannot obtain an IP address for remote peer
nitsaggy_hp Mon, 03/31/2008 - 07:08
I am facing the same issue. Sometimes the IP is assigned, and sometimes not (gives above error). Could you share the solution if it is already solved please?
Thanks & Regards
