Options for Lab Setup for Cisco UCM 5.1/6.x
Aug 30th, 2007
We are on CCM 4.1.3 and I have a lab of the same version level for pilot and testing purposes. I am now getting ready to go to Cisco UCM 5.1 or 6.0. What would be my option(s) to bring up a 5.1/6.0 lab on new hardware while keeping the current 4.1.3 production intact. When ready, I will upgrade the 4.1.3 servers and still want to keep the 5.1/6.x lab. Your suggestions are appreciated very much.
mchandak Thu, 08/30/2007 - 16:17
I'd say you should test CUCM 5.1 on your Lab server and see how it works. Please note that there is no direct upgrade Path from CM 4.1 to 6.0. So, you would either have to upgrade to CM 4.2 or to 5.x before you can move to 6.0.
Once your testing is complete and you know that CM 5.1 works the way you want it to, you should upgrade your Production System to CM 5.1.
vlaxamana Fri, 08/31/2007 - 10:05
Thanks for the clarification and suggestion. My challenge is more around the licensing area. How do I get a license for lab purpose only without invalidating my current production environment? It seems that to actually activate the services, you need to have an activated license.
