Q931 Debug Syslog Entries
Aug 30th, 2007
Is there a way that I can setup a session ID for the different Q931 debug entries that are placed in my syslog? I have 2 H323 gateways and when trying to parse through the entries for 1 call, it is very difficult to know which entries are for what calls when we have multiple calls being logged at the same time. If I can put a session ID like what is in the IPCC MIVR logs, then it will make it much easier to track all the entries from start to finish for the calls.
Thanks in advance for any help.
Avner Izhar Fri, 08/31/2007 - 07:13
  • Bronze, 100 points or more
The callref field in the 'debug isdn q931' is unique per call, per gateway. Which means that per call you will have two callref fields, one per gateway.
HTH, Avner.
