Problem with Extension Mobility and IPCC
Aug 30th, 2007
I had running Extension Mobility in my CM 4.0 but after installing the IPCC 3.5, co-resident my Extension Mobility stops working. i know this a known issue but i can`t find the answer. Any idea? Thanks
Avner Izhar Fri, 08/31/2007 - 07:04
What is not working in EM after the install? I know about some tomcat issues with co resident ipcc, but the symptoms are different. Please describe the symptoms.
Regards, Avner.
germanhernandez Fri, 08/31/2007 - 08:59
Yes, the extension mobility is not working. I just press the button and nothing happens. any idea?
thanks for ur reply
germanhernandez Tue, 10/16/2007 - 15:14
I already tried ur suggestion, but i can`t find the file SERVER.MCDVD.xml, i just found the file SERVER.XML and locate the port 8009 and changed for 8010, and restarted the server. but seems like i still having the same problem. even if i go to
i can see the tomcat services up and running
Callmanager version 4.0.2a
Any suggestion??
