CUE remote site problem
Answered Question
Aug 30th, 2007
I seem to be having some problems with using CUE on the remote site. This is my setup
Site A <--- H323 ---> Site B
Both sites are running their own CUE respectively and the H323 trunk works as I am able to dial the remote site's extension number. However, when no one answers and it is forwarded to voicemail, I seem to get a busy tone. Any ideas? The VM works when from the same site and from external calls.
Correct Answer by Rob Huffman about 9 years 7 months ago
Hi Alex,
This sounds like a Codec mismatch problem, CUE only supports g.711. Have a look at this recent thread with some really excellent answers from Brandon;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddeb8c1/8#selected_message
Hope this helps!
Rob
PS: nice to see you back Paolo (did you have a nice vacation I hope :)
Overall Rating: 5 (2 ratings)
paolo bevilacqua Sun, 09/02/2007 - 11:47
  • Hall of Fame,
    Founding Member
do you have allow connections h323 to sip in the configuration ?
alexwzh Sun, 09/02/2007 - 15:43
Yup. This is already in the configuration....
Correct Answer
Rob Huffman Sun, 09/02/2007 - 15:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alex,
Hope this helps!
Rob
alex goshtaei Mon, 08/04/2008 - 10:34
Hi All,
I have the same issue, but in my case there is no busy signal from CUE, actually when I call from site A to site B and nobody answers the call in site B, CUE picks the calling number from site A as susbscriber for voicemail and it says "there is not voicemail associated with that user". Also I configure "mailbox-selection orig-called-number" in the voicemail dial-peer, but still it picks caller number as subscriber. any suggestion would be very appreciated.
thanks
Alex
