PIX501 Login
Aug 30th, 2007
Can anyone help me out here? I have a new client that is using a Cisco PIX 501. When I Telnet to the internal IP address, I get the log in screen, but the only thing that comes up is password and it will not let me type anything in. I am at a crossroads here as I need to open Outbound traffic for a Backup program. Any help is appreciated.
Richard Burts Thu, 08/30/2007 - 18:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Andy
Depending on how the PIX is configured the prompt for only password when you telnet is normal. And the normal behavior is at the password prompt to accept the keystrokes that you enter but not to echo them back - which may look like it is not letting you type. Are you sure that it is not letting you type anything? If you type the character string that is the configured password and hit enter what happens?
Rick
NWUpgrades Thu, 08/30/2007 - 18:55
It just keeps going back to the password prompt until I have done it 3 times and then the connection ends. Not even sure if the password is correct or not. I took over for the person that originally set this up and he refuses to give my client any info. Is there a default password that I can try?
JORGE RODRIGUEZ Thu, 08/30/2007 - 20:09
  • Green, 3000 points or more
Hi Andy, is it possible you are not giving the right password? can you try terminal emulator and connect to pix via console port and try that way, you'll know then if you are indeed using correct password, otherwise you will need to do password recovery.
Jorge
NWUpgrades Thu, 08/30/2007 - 21:11
How do I do the Terminal emulator? and then how would I do a password recovery? I am a bit new to Cisco products. Thanks for the help.
JORGE RODRIGUEZ Thu, 08/30/2007 - 23:29
You need a serial console cable in order to connect to PIX console port and a PC or laptop serial, then load hyperterminal from Windows, usualy COM1 and settings as:
Bps= 9600
Data bist = 8
Parity = None
Stop bits = 1
Flow control = hardware
This will allow you to connect to PIX via local console and login to pix that way, hopefully your password will work.
After you establish console connection try the passwords, in the event you cannot login then reference password recovery link bellow, but try your best to find out the enable password .
Password recovery procedure for PIX
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_password_recovery09186a008009478b.shtml
If I dont reply further I will be off on a week vac but others will assist.
Jorge
NWUpgrades Thu, 08/30/2007 - 23:50
Thanks for the help. I will be on site on Saturday so hopefully this will work. Just one other thing, how do I determine which version of the software that is on the unit?
JORGE RODRIGUEZ Sat, 09/01/2007 - 16:41
when you initially stablish the local console via serial connection from laptop to pix you should see a prompt as:
pix>
issue a that prompt "show version" , I belive you should be able to get this info in non enable mode, however, I believe during reboot process it may also display version code as well.
Jorge
