Problem with CAR!
Aug 30th, 2007
Hi all,
My company use CCM4.1 for phone system. We use CAR tool for reporting. But recently we have a problem with this tool: when login to the site (https://CCM-SVR/art), it gives us an error message: [LDAP Access Error. Contact System Administrator.]. Could anyone give me some advices on this?
Thanks and regards,
hoanghiep
gogasca Sun, 09/02/2007 - 14:35
  • Green, 3000 points or more
Are you using DCD or AD integration?
Have you already reinstall the plugin?
hoanghiep Sun, 09/02/2007 - 15:46
I've tried to install the Customer Directory Configuration Plugin (for AD integration) but the installation failed and we currently use DCD, I've already reinstalled the CAR plugin but it didn't work.
vjemin Tue, 09/18/2007 - 12:49
Hi, I have the same problem.
I have upgraded CCM to 4.1(3) and after that I can get logon screen, but when I write previously username and password I got:
I am using AD integration.
Abdulbaseer Mohammed Fri, 09/28/2007 - 21:49
  • Silver, 250 points or more
the problem is your user. try re seting that user after the upgrade or if you can delete and re create.
Baseer.
