08-31-2007 01:22 AM
One of my customer already have ciscoworks 2000 and they will buy HP Openview 7.5 and want them to integrate together, like you can use ciscoview from HP Openview. Is that possible ? If so what do I have to do to make them work together ?
Any help/advices and very appreciated.
Thank you,
Jan.
08-31-2007 05:25 AM
What version of CiscoWorks LMS are they running?
You can integrated LMS 2.6 with NNM 7.5
If they are to be on same server you can use the adapter from the following link:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-nnm
(also download readme for directions).
Readme does mentions:
Adapter(Version 1.7) for integrating Cisco Applications and Cisco Devices
into HP Network Node Manager 6.4 , 7.0 , 7.01 and 7.5 versions
If you are installing NNM on separate server, you can you use the Integration Utility (IU) on the remote server where HP NNM is installed which you may download from this link:
08-31-2007 07:35 AM
08-31-2007 07:47 AM
This is 2.0 which is over 7 years old, so it won't be able to integrate with NNM 7.5
08-31-2007 08:05 AM
No other way to integrate at all ? Please advice if there is any alternative ways to do.
Thank you,
Jan
