aironet 1200 and AWCVX-MIB.my
Aug 31st, 2007
(firmware 12.3JEB)
I want to distinguish if an AP is in 802.11 a or b / g mode.
I have tried to get specific information from AWCVX-MIB.my.
For example i have tried to read AWCVX-MIB::awcDot11CurrentCarrierSet,AWCVX-MIB::awcDot11CurrentChannel
objects but the above MIB is not supported ):
The strange thing is that the web interface can distinguish if the radio interface operates at 2.4GHz or 5GHz and also can distinguish the mode a or b/g.
Is there an alternative solution to find this information through SNMP?
David Stanford Fri, 08/31/2007 - 06:53
  • Cisco Employee,
You might want to look at the CISCO-DOT11-RADIO-DIAGNOSTIC-MIB and the CISCO-DOT11-ASSOCIATION-MIB to see if they provide the objects you are looking for.
theodionys Mon, 09/03/2007 - 05:44
I still can't get the information from the above MIBS...
SNMP Output(For 3 connected Clients) - Cisco Aironet 1200 firmware version-->12.3JEB
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientRadioType.1."gstam-cisco".'.....a' = INTEGER: unknown(1)
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientRadioType.1."gstam-cisco".'.....'' = INTEGER: unknown(1)
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientRadioType.1."gstam-cisco".'..~.!y' = INTEGER: unknown(1)
CISCO-DOT11-RADIO-DIAGNOSTIC-MIB::cDot11RadioDiagTempChannel.1 = Gauge32: 0
CISCO-DOT11-RADIO-DIAGNOSTIC-MIB::cDot11RadioDiagTempTxPowerLevel.1 = Gauge32: 0
CISCO-DOT11-RADIO-DIAGNOSTIC-MIB::cDot11RadioDiagMode.1 = INTEGER: 0
CISCO-DOT11-RADIO-DIAGNOSTIC-MIB::cDot11RadioDiagSettingsEnabled.1 = INTEGER: false(2)
CISCO-DOT11-RADIO-DIAGNOSTIC-MIB::cDot11RadioDiagTempClientTxPower.1 = Gauge32: 0
CISCO-DOT11-RADIO-DIAGNOSTIC-MIB::cDot11RadioDiagTempDataRateSet.1 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00
arunsprasath Mon, 12/10/2007 - 06:11
cDot11RadioDiagMode OBJECT-TYPE
SYNTAX INTEGER {
normal(1),
apRadioDiscovery(2),
siteSurveyTempSettings(3),
siteSurveyNonTempSettings(4)
Here how to use that apRadioDiscovery..
There is no description about the object value.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
