ASA 5510 wont boot up
Aug 31st, 2007
Hello
My ASA 5510 wont boot up. It was working fine before I rackmounted it. Now I'm just getting the following messages repeatedly. I've tried contacting Cisco but they wont talk to us because we didn't purchase support with the device (despite the device being less that 1 year old). Please help
CISCO SYSTEMS
Embedded BIOS Version 1.0(11)2 01/25/06 13:21:26.17
Low Memory: 631 KB
High Memory: 256 MB
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 2578 Host Bridge
00 01 00 8086 2579 PCI-to-PCI Bridge
00 03 00 8086 257B PCI-to-PCI Bridge
00 1C 00 8086 25AE PCI-to-PCI Bridge
00 1D 00 8086 25A9 Serial Bus 11
00 1D 01 8086 25AA Serial Bus 10
00 1D 04 8086 25AB System
00 1D 05 8086 25AC IRQ Controller
00 1D 07 8086 25AD Serial Bus 9
00 1E 00 8086 244E PCI-to-PCI Bridge
00 1F 00 8086 25A1 ISA Bridge
00 1F 02 8086 25A3 IDE Controller 11
00 1F 03 8086 25A4 Serial Bus 5
00 1F 05 8086 25A6 Audio 5
02 01 00 8086 1075 Ethernet 11
03 01 00 177D 0003 Encrypt/Decrypt 9
03 02 00 8086 1079 Ethernet 9
03 02 01 8086 1079 Ethernet 9
03 03 00 8086 1079 Ethernet 9
03 03 01 8086 1079 Ethernet 9
04 02 00 8086 1209 Ethernet 11
04 03 00 8086 1209 Ethernet 5
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(11)2) #0: Thu Jan 26 10:43:08 PST 2006
Platform ASA5510
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Launching BootLoader...
Default configuration file contains 1 entry.
Searching / for images to boot.
No images in /
Error 15: File not found
unable to boot an image
No images in /
Failsafe booting engaged.
No images in /
purohit_810 Fri, 08/31/2007 - 06:09
  • Silver, 250 points or more
It passed out from interface detection..
Advice you to please check IOS is there or not?
In monitor mode give DIR command.. it will show you.
If you find an IOS at there please, Boot device by using that IOS.
Command is: boot system disk0:/asa722-k8.bin
If you are unable to get in monitor mode than..upload IOS into that and try to beet.
Dharmesh Purohit
Rex Biesty Fri, 08/31/2007 - 06:16
Thanks for the reply. I eventually got Cisco to talk to me who have diagnosed it as a hardware issue and are shipping a new device out. Thanks for the help anyway.
