Dead Peer Detection does not work !!!
Aug 31st, 2007
I have two 2811 VPN routers connected via several switches. Static crypto maps and isakmp keepalives at 10seconds.
Tunnel is up and working, encrypting traffc between loopbacks on the 2811s when I do extended pings.
Everything works fine. I do a show crypto isakmp sa detail and can see the security association and remaining lifetime.
I now kill a link betwen the switches, isolating the 2811's. I can no longer do my extended ping between the loopbacks between the 2811's, as would be expected. However, why isn't the DPD taking the SA down? When I do a show cryto isakmp sa detail again, there is no difference to the output when the VPN was up and running. I AM generating traffic so why isn't the SA being deleted? I have NTP running with teh source address as the loopbacks so there is always interesting traffic.
If I use periodic keepalives it works properly and the SA drops out. However, I am labbing this problem because with my customer a 6500 VPN SPA is the tunnel endpoint and this does not support periodic keepalives !!!
Thanks for your help.
meverett Tue, 10/23/2007 - 10:25
your message caught my interest. Worked on previous problem where this appeared to be the problem.. In my case, there was a fw in the middle that did not have all the right IPSec ports open.. However, during troubleshooting Cisco TAC sent over a doc in regards to invalid SPI recovery for IOS routers.. Essentially, a feature that can be enabled to more quickly detect a failed peer. You may want to look into this feature
