Problem with FXO ports
I connected some PSTN lines on FXO port which are on a EVM-HD-8FXS/DID module on a cisco router 3825. But when a call comes from outside it does not ring on the phone of the operator. The outgoing call are well routed through the FXO ports.
This is the command I put on each FXO port:
voice port 2/0/8
connection plar opx 4094
When I connect an analog phone on the PSTN line, it rings. The phone of the operator works very well.
What could be the problem ?
Can someone help ?
tom.gill
Can you provide more of your config? I'm assuming you're running CME?
I am running a CCM 4.1.3sr5b. Find in attached the configuration of my router.
yatisspor
Did you write any dial-peer for these calls? For examle;
dial-peer voice 100 voip
destination-pattern 4094
session target ipv4:"CM ip"
The incoming calls are coming from the PSTN lines. I tried your command but it does not work. Please find in attached the config of my router.
Thanks in advance !
