crypto applied on Loopback interface
Answered Question
Aug 31st, 2007
The following is the config from one of our 2811 router, we applied crypto on loopback interface but its not working. Can you review the cofig and let us know the suggesstion as where else we can apply crypto MAP to VPN to work.
site#sh run
Building configuration...
Current configuration : 5956 bytes
version 12.4
service password-encryption
hostname Site
boot-start-marker
boot-end-marker
enable secret cisco
no aaa new-model
resource policy
memory-size iomem 25
clock timezone EST -5
clock summer-time EDT recurring
no network-clock-participate wic 2
no network-clock-participate wic 3
ip subnet-zero
ip cef
no ip dhcp use vrf connected
controller T1 0/2/0
framing esf
linecode b8zs
cablelength short 133
channel-group 0 timeslots 1-24
controller T1 0/2/1
framing esf
linecode b8zs
controller T1 0/3/0
framing esf
linecode b8zs
controller T1 0/3/1
framing esf
linecode b8zs
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp key wsld0829 address 66.78.246.175
crypto ipsec transform-set rtpset esp-3des esp-md5-hmac
crypto map rtp 10 ipsec-isakmp
set peer 66.78.246.175
set transform-set rtpset
match address 110
interface Loopback0
description **** IP Address of Multilink Serial Lines ****
ip address 168.88.110.200 255.255.255.252
crypto map rtp
interface Serial0/0/0
description **** To Sprint HCGS/987682//LB ****
no ip address
encapsulation ppp
no fair-queue
pulse-time 1
ppp multilink
crypto map rtp
interface Serial0/1/0
description **** To Sprint HCGS/987683//LB ****
no ip address
ip verify unicast reverse-path
no ip redirects
no ip unreachables
encapsulation ppp
no fair-queue
pulse-time 1
ppp multilink
interface Serial0/2/0:0
no ip address
no ip redirects
no ip unreachables
encapsulation ppp
no fair-queue
pulse-time 1
ppp multilink
crypto map rtp
interface Serial0/2/1:0
no ip address
no ip redirects
no ip unreachables
encapsulation ppp
no fair-queue
pulse-time 1
ppp multilink
crypto map rtp
interface Serial0/3/0:0
no ip address
no ip redirects
no ip unreachables
encapsulation ppp
shutdown
no fair-queue
pulse-time 1
ppp multilink
interface Serial0/3/1:0
no ip address
no ip redirects
no ip unreachables
encapsulation ppp
shutdown
no fair-queue
pulse-time 1
ppp multilink
interface Virtual-Template1
ip unnumbered Loopback0
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 160.81.110.209
ip route 200.3.201.0 255.255.255.0 207.40.33.100
ip route 203.13.189.0 255.255.255.0 207.40.33.100
ip http server
no ip http secure-server
access-list 110 remark Tunnel ACL
access-list 110 remark Allowing router loopback
access-list 110 permit ip host 168.88.110.200 67.210.111.204 0.0.0.15
access-list 110 remark Allowing IP3
access-list 110 permit ip host 207.41.32.106 65.210.126.240 0.0.0.15
access-list 110 remark Allowing devices
access-list 110 permit ip 208.3.187.0 0.0.0.15 65.210.126.240 0.0.0.15
access-list 110 permit ip 208.3.187.16 0.0.0.7 65.210.126.240 0.0.0.15
access-list 110 permit ip 208.3.187.24 0.0.0.1 65.210.126.240 0.0.0.15
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login local
end
Your suggestion will be highly appreciated.
khan
Correct Answer by jerrytozhang about 9 years 9 months ago
1: try to add the following command into your router.
multilink virtual-template 1
2: put "crypt map rtp" command into virtual-template 1 sub-configuation.
3: remove "crypt map rtp" command from all serial interface sub-configuration and loopback interface.
4: highly recommended to remove the following command from each serial interface.
5: if still doesn't work, reapply "crypt map rtp" command into all serail interfaces sub-configuration.
Jerry
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 08/31/2007 - 04:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Try adding this to your config
crypto map rtp local-address loopback0
Jon
azmath.hk Fri, 08/31/2007 - 05:08
Jon,
I tried the above command, its accepting but not showing in the configuration...Also not able to ping from management subnet.
Any suggesttion or help?
azmath.hk Fri, 08/31/2007 - 05:33
Able to establish the tunnel but cant ping the router loopback from management station?
Please help me!!!!!!!!!!
Jon Marshall Fri, 08/31/2007 - 05:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
what is the management station IP address ?
azmath.hk Fri, 08/31/2007 - 05:47
Jon,
Thanks for your help.
Here is the management stations IP 65.210.126.240 ....
Correct Answer
jerrytozhang Fri, 08/31/2007 - 07:01
Jerry
azmath.hk Fri, 08/31/2007 - 07:07
Jerry,
I tried applying the crypto map rtp into virtual-template 1 but did not work out.
Please help me out...
azmath.hk Fri, 08/31/2007 - 07:21
because virtual-template 1 interface is IP unnumberred...on unnumberred interface u cant apply crypto map
jerrytozhang Fri, 08/31/2007 - 09:16
try apply the crypto map rtp into your loopback, please don't forget removing "ip verify unicast reverse-path"
azmath.hk Fri, 08/31/2007 - 09:29
Jerry,
I tried applying ctypto map rtp into loopback 0 interface but did not work..
I have noticed that virtual-template 1 is accepting crypto map rtp command but still did not work.
I have seen that virtual-access interface is getting IP from fastethernet 0 interface, i dont know why?
But as soon as i add this static route:-
ip route 0.0.0.0 0.0.0.0 loopback 0
I am able to ping from management station,but not able to ping inside device which was pingable before adding this route on router.
I am not able to understand why we are able to ping when we add the above default route and why not able to access the inside server from management?
valuable suggestion will be highly appreciated.
khan
azmath.hk Mon, 09/03/2007 - 09:05
Jerry/all,
I configured everything bit as suggested by Jerry, but still not able to ping from management station.
I have noticed something stanged is that virtural-template 1 in showing down down when i type show ip int bri command.
Is there any way to bring this up and makes things work...
Any help at this point will be highly appreciated.
Khan
azmath.hk Tue, 09/04/2007 - 03:26
Jerry,
Its working now after i rebooted the router...
Thanks you ver much..
Khan
jerrytozhang Tue, 09/04/2007 - 07:25
Haha,,, finally, it works, it's great for me.
So, Can you kindly paste your final configuration there, other people can easily benefit from your configuration, and I don't need to answer this similar question anymore :).
Jerry
azmath.hk Tue, 09/04/2007 - 08:24
Jerry,
Sure, I will paste and rate your inputs.
Could you please tell me what exactly the following command does, because as soon as i removed this command everything started working fine so far.
Khan
jerrytozhang Tue, 09/04/2007 - 08:55
ip verify unicast reverse-path is a security feature, it's been Cisco IOS router and PIX firewall a long time.In a summary, this security feature just verify the packets the router receive on a port where respective retunning packets should be forwarded out
through. one port in and same port out!
go to see the URL below for more detail:
http://www.cisco.com/en/US/partner/products/ps6350/products_configuration_guide_chapter09186a00804fdef9.html#wp1000928
Jerry
