Voice Gateway Config
Aug 31st, 2007
I'm building my first voice solution and would like to see examples of what I'm trying to acheive.
Basically remotely connected agents on softphones will be dialling local extension on my PBX. The PBX is connected via 4 x E1's to a 3845 GW. The 3845GW is connected to a 3725 GK. The call returns to the remote agents over IP.
The one aspect that I can't get my head around is dial peers. Can anyone recommend an example from what I'm trying to achieve?
Thanks in advance.
Avner Izhar Sat, 09/01/2007 - 19:36
What are the phone numbers and ip addresses of your 3845 and call manager? That will allow me to suggest the dial-peer layout.
Regards, Avner.
