Cisco works BOM facing problem with configurator
Aug 31st, 2007
I need to prepare a BOM for cisco works to manage 40 cisco devices and LAN network, but facing problem in configruator, can you send me the required details ASAP
David Stanford Fri, 08/31/2007 - 05:21
  • Cisco Employee,
What is the problem you are facing? What version of Cisco Works are you looking at?
sandeeprg Sat, 09/01/2007 - 07:12
part number CWLMS-3.0-100-K9 for which configurator not allowing me to check and download the config.
Joe Clarke Sat, 09/01/2007 - 14:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This part number is not configurable. Just add it as-is to your order list (i.e. in the Ordering Tool).
