Cisco 2811 Frame Relay Hardware Compression
Aug 31st, 2007
Does the Router C2811 with VPN/SSL module support hardware compression for frame relay??
the command "show pas caim 0" say unrecognised command and "show compress" outputs only software compression.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T4, RELEASE SOFTWARE (fc2)
Technical Support:
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 07-Jun-07 04:42 by prod_rel_team
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ112970F6
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
pankajjankee Sun, 09/02/2007 - 21:20
Dharmesh, I made some research on IPPCP and it does hardware encryption and software compression. What i am looking for is if its possible to make hardware compression on Serial interface using the AIM-VPN/SSL module. If yes what are the commands since i have tried a few commands and it still didnt work out.
