Applied FAC, phone prompt 4 UNKNOWN # instead enter AUTHORIZATION CODE
Aug 31st, 2007
I have successfully Applied FAC (force authorization code), but phone prompt for To:UNKNOWN NUMBER instead of ENTER AUTHORIZATION CODE to complete the call, I would like to extend the delay for few more seconds so user can easily enter code before busy tone.
hadbou Thu, 09/06/2007 - 06:41
  • Bronze, 100 points or more
For a workaround, delete the route pattern, and re-insert it with the desired configuration. Do not modify it. Modification after insertion re-creates the problem.
azfarlashari Thu, 09/06/2007 - 21:07
Thanks for your kind email but now I am concerned to CONFIGURE THE PROMPT which must ask ENTER AUTHORIZATION CODE.
azfarlashari Mon, 09/10/2007 - 00:03
Dear, FAC is successfully applied but instead of asking for code (Enter Authorization Code) it says TO: UNKNOWN NUMBER - after entering code it dials to DESTINATION successfully so I my view there is no problem in Route Pattern. Please advice
