Billing system RTS with AS5400
Aug 31st, 2007
dears,
i have problem with AAA i have a billing system i need AS5400 to make AAA with it
i did this configuration :
3. aaa new-model
4. aaa authentication login default group radius
5. aaa authorization exec default group radius
6. aaa accounting connection default start-stop radius
7. radius-server host
8. radius-server host non-standard
9. radius-server key
10. radius-server vsa send accounting
radius-server vsa send authentication
11. gw-accounting aaa
12. adius-server host 171.69.58.104 auth-port 165 acct-port 1646
13.radius-server key testing123
and did not work and no radius packet reach radius server .... i need your help please.
thx
teodorgeorgiev Fri, 09/14/2007 - 00:35
  • Bronze, 100 points or more
It will not.
You have to configure the AAA class not for "default", but for h323.
aaa accounting connection h323 start-stop radius
Add this command and then run:
debug radius accounting
debug radius verbose
term mon
and you will see how the Cisco GW will start sending accounting packets to the billing system (Radius server).
Then, if you want h323 authentication as well:
aaa authentication login h323 group radius
tareqrebhi Sun, 10/28/2007 - 00:22
thank you,
dear i have important question i need to implement and configure my Voice Gateway AS5400 to send numbering with E.164 formate do you have any ideas about the commands i need to put at my GW?
