VPN tunnel with multiple set peer
Aug 31st, 2007
I have a ip sla monitoring one of the interfaces so when the fa0/0 interface goes down, the backup interface takes over and uses the other set peer. However when the fa0/0 interface comes up the crypto map ipsec does not start the on the original set peer, it never clears the isakmp. I have to go in and clear it manually. Is there anyway of having the crypto map clear automatically when the original interface comes up?
a.alekseev Sun, 09/09/2007 - 15:26
  • Gold, 750 points or more
I think "crypto isakmp keepalive " should help.
