mohammedmahmoud Fri, 08/31/2007 - 10:12
  • Green, 3000 points or more
You can enable Syslog logging using "logging " and make sure to have the command "logging event link-status" under the interfaces.
HTH,
Mohammed Mahmoud.
yoyo_the_king Mon, 09/03/2007 - 04:53
thanks Mohammed,
if you can tel me what difference between:
- snmp trap link-status
and
- logging event link-status
mohammedmahmoud Mon, 09/03/2007 - 06:09
snmp trap link-status > sends snmp trap to the NMS for interface status.
logging event link-status > sends logging to a syslog server for interface status.
HTH,
Mohammed Mahmoud.
ohassairi Fri, 08/31/2007 - 10:40
  • Silver, 250 points or more
yoyo
if you have no syslog server, you can download a free one : http://www.kiwisyslog.com/index.php
but if you use subinterfaces with frame relay, may be you will not receive a log msg when only one lgical interface (and not the physical) comes down.
mohammed, did you face this problem before? i think in this case we must use SNMP traps.
mohammedmahmoud Fri, 08/31/2007 - 10:51
Hi Oussama,
For subinterfaces you must make sure that the command "logging event subif-link-status" is under the main/physical interface.
HTH,
Mohammed Mahmoud.
yoyo_the_king Tue, 09/04/2007 - 03:18
thank you for your response,
another question plz,
there is possibility on router to send trap when time to ping a specific host exceed for exemple 100 ms?
