Translation Patterns E1
Aug 31st, 2007
I have an MGCP implementation and an E1 implementation and all 8 digits are passed to us. We need to translate this to 5 digits to pass to the phone. We created a translation pattern from all 8 digits to 5 digits, and the call cannot be completed. The error we are seeing from the debugs states: unallocated/unconfigured number. My question is how we translate this number to 5 digits.
Thanks!
steven.lass Fri, 08/31/2007 - 07:41
Assuming that you are using CCM, set the "Significant Digits" to 5 for "Inbound Calls" on the CCM gateway config.
cplatt01 Fri, 08/31/2007 - 09:56
Yes it is a CCM installation. Tried that, and still a no go...hmmm...not sure what to try now!
steven.lass Fri, 08/31/2007 - 10:46
Does the CSS for the gateway inbound calls contain the partition with the DNs?
steven.lass Fri, 08/31/2007 - 13:12
Hmmm, I'm out of easy answers. Here are the steps I would take:
1) on the gateway, 'show mgcp' to verify the gateway is registered.
2) make calls in the other direction (outbound) to further validate the mgcp configuration
3) on the gateway, 'debug mgcp events' to verify mgcp is being triggered for inbound calls.
4) turn on 'detailed' trace on the CCM and dig thru the logs.
good hunting
Sascha Monteiro Sat, 09/01/2007 - 02:20
if you have a translation pattern,
is it in a partition that is in the list of the CSS that is on the gateway?
And is the CSS on the translation pattern correct, so it can find the DN's of the phones?
Is the MGCP endpoint registered?
try a reset there too, or from enable mode on the gateway;
ccm-manager config-download check-configuration reset
hth
