MPLS Cisco Certification
Answered Question
Aug 31st, 2007
Which Cisco certification covers MPLS technology?
Correct Answer by devang_etcom about 9 years 6 months ago
hi,
You can take CCIP MPLS exam but before that you need to have proper understanding of the Routing environment so its better to go for whole CCIP which will cover your Routing-IGP, BGP, MPLS and QOS so it will make your foundation strong and learning process easy...
regards
Devang
Correct Answer by mohammedmahmoud about 9 years 6 months ago
Kindly check the following:
http://www.cisco.com/web/learning/le3/current_exams/642-611.html
And please be ware that it is one of the challenging exams.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (3 ratings)
Correct Answer
devang_etcom Fri, 08/31/2007 - 11:00
  • Gold, 750 points or more
hi,
regards
Devang
debasmita Mon, 09/17/2007 - 09:11
Hi everyone,
I am new to MPLS. I am very much interested in this field.Which certification course should I take to take the 642-611 exam? I have not worked in this field.Can any one please help me.
Debasmita.
devang_etcom Mon, 09/17/2007 - 09:59
You should go for the routing and switching exam first... as routing and switching is the base for all other services...
debasmita Mon, 09/17/2007 - 10:51
what is the certification course for routing and switching exam and can you please let me know what is that exam called?
I found for mpls, there are three classroom courses.
1.Implementing Cisco Traffic Engineering & other features(MPLST)v2.0
2.Implementing Cisco MPLS(MPLS)v2.1
3.Implementing Cisco MPLS(MPLS)v2.2
which one is helpful for 642-611 exam?
Thank you.
swaroop.potdar Mon, 09/17/2007 - 11:10
  • Blue, 1500 points or more
Before going on with 642-611, it would be a good idea to go as below in sequence. And keep progressing as you gain condfidence.
1) Building Scalable Cisco Internetworks (BSCI) v3.0
642-901 BSCI
2) Configuring BGP on Cisco Routers (BGP) v3.2
642-661 BGP
And then 642-611 and related courses. As a good foundation in the above 2 topics would be helping you much for MPLS.
HTH-Cheers,
Swaroop
debasmita Tue, 09/18/2007 - 11:51
since i am new to this field do i have to take any other course before taking BSCI?
i do not have any experience on this field.
thank you.
debasmita Sun, 09/23/2007 - 20:47
what is the best book or course to prepare for the exam 642-901 BSCI and 642-661 BGP?
please let me know.
Thank you.
