BARS: Unable to backup cdr.dmp
Answered Question
Aug 31st, 2007
My server is currently running on BARS version 4.0.8000 and it seems that it's unable to backup cdr.dmp.
I attached the log.
Any advice is very much appreciated.
Correct Answer by rob.huffman about 9 years 4 months ago
Hi Steve,
Here is an excellent clip from Jorge @ Cisco
"The event that you see in the App log is not a problem. It is telling you the SQL backup
has completed and as such the transactional logs are not needed and so are deleted. This
is so because if we keep the transactional logs the size of the Database will increase
causing disk space shortage and hence we will have issues with services stopping.
MCS BackupUtility by default " deletes " the transactional [ ART / CDR ] logs after a
backup. When this is done you will see the error you mention. This is nothing to worry
about. MCSBackup basically reduces/removes unnecessary data to be backed up, grab a copy
of the database, and backup this copy to the stream file. I think it would be better that
message type is changed from Error to Information by Microsoft."
From this great thread;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde2ca5/1#selected_message
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Sat, 09/01/2007 - 09:09
Hi Steve,
Hope this helps!
Rob
steve-yong Mon, 10/01/2007 - 18:37
Hi Rob,
Thanks for the link. I did saw the thread but I didn't realize that it applicable to my problem.
Again, thanks. :)
rob.huffman Thu, 10/04/2007 - 19:43
Hi Steve,
You are most welcome :) That is an interesting one for sure. Gives you scare when you first see it!
Take care,
Rob
