PIX subinterface and "switchport mode" conflict
Aug 31st, 2007
I created a subinterface on a PIX-515E (7.2.2) but I cannot arping it unless I set the switch port to "switchport mode trunk".
But then the main interface on the PIX stops working, failover claims the status of the main interface is "unknown" and the firewall does not pass traffic.
Set the port back to "switchport mode access", the firewall starts working fine again, but the subinterface is not accessible anymore.
Any suggestions?
purohit_810 Fri, 08/31/2007 - 12:32
  • Silver, 250 points or more
Port bydefault been in access mode, if you have configured it in TRUNK that need to give access command otherwise don't.
See in attachment how can you use the same command:
hostname(config-if)# interface ethernet 0/1
hostname(config-if)# switchport mode trunk
hostname(config-if)# switchport trunk allowed
Dharmesh Purohit
sundar.palaniappan Fri, 08/31/2007 - 15:01
  • Green, 3000 points or more
Configure these two commands on the 2960 switchport that connects to the PIX and try.
Sundar
