Jon Marshall Fri, 08/31/2007 - 13:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You don't need to add this as there is an implicit deny at the end of the access-list anyway so any packets not permitted in your access-list will be dropped.
The only reason you may want to add it is so you can see how many packets your firewall is dropping by looking at the hit counters.
Jon
purohit_810 Fri, 08/31/2007 - 17:03
  • Silver, 250 points or more
That is true, Implicit deny always there... But it is require only the time of troubleshooting or some of testing time.
to check the hit comes ot not...by command
show access-list outgoing
Dharmesh Purohit
