USR 56 Fax Modem Fails to As5400 Nextport Modems
Aug 31st, 2007
I have cut over an 800 # to my As5400's and a some users with USR 56k Fax modems can not negotiate a connect. Does anyone know of any possible fixes either to USR modem or As5400.
I have set modemcap on AS5400 to S29=6 to skip V.92. It appears I have the same problem if these USR modems dial an As5300 with Mica modems also.
Need some recommendations to try
Overall Rating: 1 (1 ratings)
umedryk Thu, 09/06/2007 - 09:17
  • Bronze, 100 points or more
When implementing Store and Forward Fax on a modem card, the off-ramp gateway does not necessarily need to have MMoIP dial peers configured to establish connectivity with the receiving fax device; therefore, off-ramp MMoIP dial peers are optional when using a modem card. You basically use off-ramp MMoIP dial peers if you need to specify a particular resolution for the fax transmission or if you need to define an encoding type. For example, it might suit your company's needs to send the fax-mail using the least definition as possible to save network resources. In that case, you might want to define a higher image resolution using an off-ramp MMoIP dial peer. Another case where you might want to use an MMoIP dial peer would be if the fax devices in your network could only process a particular type of encoding or compression. If you do decide to configure a MMoIP dial peer, be sure to match the incoming called number command value with the destination pattern telephone number you configured for the corresponding on-ramp POTS dial peer.
