ATM/IMA no web with one T-1 failure HELP
I have a customer with a Cisco 3640 router and a 4 ATM interfaces network module running c3640-ik9s-mz.123-14.t3.bin IOS image. The 4 T-1 ATM module is fully boated with 4 T-1's and My problem is a follows:
In the event that 1 of the 4 T-1s fails I still have layer 3 and I'm still able to SSH to the router from both the trusted and untrusted but the customer looses WEB. They simply can't surf. The can ping but not much else. When the T-1 comes back the WEB also comes back. Weird??!!
The config is as fallows:
interface ATM3/0
description Physical Interface for ##.ASXX.#####.1.ABC - Backbone T1
no ip address
no atm ilmi-keepalive
ima-group 1
scrambling-payload
interface ATM3/1
description Physical Interface for ##.ASXX.#####.2.ABC - Backbone T1
no ip address
ima-group 1
scrambling-payload
interface ATM3/2
description Physical Interface for ##.ASXX.#####.3.ABC - Backbone T1
no ip address
ima-group 1
scrambling-payload
interface ATM3/3
description Physical Interface for ##.ASXX.#####.4.ABC - Backbone T1
no ip address
ima-group 1
scrambling-payload
interface ATM3/IMA1
description Primary Connector Interface for Sub-IF
no ip address
interface ATM3/IMA1.1 point-to-point
description Connector Interface for ##.ASXX.#####.1.,.2.,.3.,.4..abc - Backbone T1
ip address ##.###.###.## 255.255.255.###
ip verify unicast reverse-path
no ip unreachables
ip accounting output-packets
ip nat outside
ip virtual-reassembly
atm pvc # # ### aal5snap
The some IMA interface is as follows:
router_#sh ima interface atm3/ima1
Interface ATM3/IMA1 is up
Group index is 33
Ne state is operational, failure status is noFailure
Active links bitmap 0xF
IMA Group Current Configuration:
Tx/Rx configured links bitmap 0xF/0xF
Tx/Rx minimum required links 1/1
Maximum allowed diff delay is 25ms, Tx frame length 128
Ne Tx clock mode CTC, configured timing reference link ATM3/0
Test pattern procedure is disabled
IMA Group Current Counters (time elapsed 619 seconds):
0 Ne Failures, 0 Fe Failures, 0 Unavail Secs
IMA Group Total Counters (last 24 hours):
IMA link Information:
Link Physical Status NearEnd Rx Status Test Status
ATM3/0 up active disabled
ATM3/1 up active disabled
ATM3/2 up active disabled
ATM3/3 up active disabled
Any help would be great
