anandramapathy Sat, 09/01/2007 - 00:22
  • Bronze, 100 points or more
check if the ASDM file is installed in the PIX / ASA. It will be in the flash with the PIX / ASA Boot image.
Dir flash:
if it is not present install the ASDM by downloading it from the cisco site. YOu may need a cisco login for this
brianbono Mon, 09/03/2007 - 10:21
check the version of your ASA...
sh ver
if it is running a ASA 8.x then try downloading the ASDM 6.x
you may have already downloaded the correct images but it was not loaded during startup. so try to verify if these configurations are present on your running config:
boot system disk0:/asa802-k8.bin
asdm image disk0:/asdm-602.bin
if not present, then enter those commands...
rate if it helps :)
