associate only with one access point
Sep 1st, 2007
Gentlemen,
I have WLC with 3 accesspoints, all them are shown in wlc and their status enable and REG, my problem is the users can associate only with one access point but they can't associate to the others ???
* Note :
in GUI - Security - AP Policies - authorized AP - there is only ONE I added the other 2 later but the same results.
Any idea ASAP,
Overall Rating: 4 (1 ratings)
Alejandro Corte... Mon, 09/03/2007 - 12:56
  • Silver, 250 points or more
so your 3 access pooint are asociated corectly if they show the REG estatus, now check the security parameters in the WLAN TAB.
sbarasiscom Mon, 09/03/2007 - 22:24
Thanks friends,
I found the problem.
The problem is I enabled WLAN Override and I didn't check any SSID , So I disabled it in the APs and now it works normaaly,
Good Luck,
Trending Topics - Security & Network
