building a home training network
Sep 1st, 2007
I am a CCNA however, I have more time on SIMs than on routers. On the job, most of my work is with legacy serial or ATM equipment. I need to build a home network. If I buy used routers and switches how do I get the latest IOS so I can practice the CCNP lessons?
Overall Rating: 2.5 (2 ratings)
nambi_gct Mon, 09/03/2007 - 02:58
  • Bronze, 100 points or more
Hi,You need to check with your equipment reseller about this.They will be able to give the rigt information.
avmabe Tue, 09/04/2007 - 14:03
You need a CCO login and rights to download the software for the devices.
wmeier5 Tue, 09/04/2007 - 16:21
O.K., I will bite. How do I get the rights? Is there a "right" to use as long as you use it for learning and not profiting?
avmabe Tue, 09/04/2007 - 16:24
You have to have a support contract on the devices. I'm not aware of any other method. I'd recommend when you purchase them to research and buy the ones with the latest codes they support.
fred.mancen Wed, 09/05/2007 - 12:04
Hi buddy.
While you do not purchase these devices, you can practice using the Dynamips simulator. It uses real IOS images and supports the 2800, 3600, 3725 and 7200 series and versions. You can find valuable info on the web regarding Dynamips, and you can design your network just editing the lab file. It is possible to change routes with a real router, for example. It is not the same fun, but is really useful to learn about networking.
I hope it helps.
Regards.
