Dynamic ARP inspection
Sep 1st, 2007
we want to enable dynamic arp inspection to disable ARP poisoning in our Local LAN. We are using cat 2960 series switches. I am unable to locate any commands relevant to DAI in cat 2960. we are using the latest software image.Appreciate if anyone can point us in the right direction
Thanks in Advance
mohammedmahmoud Sat, 09/01/2007 - 13:37
AFAIK, Dynamic ARP Inspection is not supported on the Catalyst 2960.
[edit] i've double checked and it is only supported on the Catalyst 6500/4500/3550/3560/3750, please use the feature navigator for checking.
Mohammed Mahmoud.
sharathkombathula Sat, 09/01/2007 - 15:12
Is there a way or a work around that I can try to stop ARP poisoning at switch level. I tried enabling port security but without any luck. Any help in this regard is greatly appreciated
Thanks in Advance
Joseph W. Doherty Sat, 09/01/2007 - 13:38
Release Notes for the Catalyst 3750, 3560, 2970, and 2960 Switches, Cisco IOS Release 12.2(40)SE have, in table 7:
Dynamic ARP inspection (IP services image [formerly known as the EMI] only)
3750 and 3560
If you have the IP service image, you could try the commands listed in: http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a00808a9951.html
