AAA AAA AAA problem
Sep 2nd, 2007
dears,
i have connfigured my AS5400 as SS7 GW using this configuration:
aaa authentication login sanj_aaa1 group radius local none
aaa authentication ppp sanj_aaa1 group radius local none
aaa authorization exec sanj_aaa1 group radius local none
aaa authorization network sanj_aaa1 group radius local none
aaa accounting connection sanj_aaa1 start-stop group radius
voice class aaa 1
authentication method sanj_aaa1
authorization method sanj_aaa1
accounting method sanj_aaa1
radius-server attribute 6 on-for-login-auth
radius-server host 55.55.55.1 auth-port 1812 acct-port 1813 key 7 hello
radius-server timeout 50
radius-server deadtime 1
radius-server key 7 hello
radius-server vsa send accounting
radius-server vsa send authentication
gw-accounting aaa
gw-accounting aaa
but i recieved these error message:
*Jan 2 06:13:58.956: voip_rot_acct_supp_enabled: Rotary suppress disabled
*Jan 2 06:13:58.960: voip_update_ccapi_accounting(1465): WARNING: accounting start not send. return.
*Jan 2 06:13:58.984: get_acct_params(1466): ERROR: method "h323" not defined.
any help please...
teodorgeorgiev Mon, 09/03/2007 - 22:44
  • Bronze, 100 points or more
aaa accounting connection h323 start-stop group radius
this is the correct command.
tareqrebhi Tue, 09/04/2007 - 08:39
but i did not use h323 i am using SIP so also i need to add this command.... what about else it is correct.
thx......
teodorgeorgiev Fri, 09/14/2007 - 00:37
Even if you use SIP, the H323 AAA commands will do the job as well!
