davidmeiker Mon, 09/27/2010 - 17:51
Greetings
The CE500 have a CLI Mode, Yes it have! and you can force your interface!
But In my humble opinion I think its a Emulation of the CLI
When you do all the configuration in the SW, just type in you internet explorer.."http:// + IP Swithc + /exec" for example "http://192.168.10.2/exec"
And you can emulate the CLI in the CE500.
josue jonathan ... Thu, 04/19/2012 - 15:39
Hi Jose Quintero...
i try change the configuration the port in the switch catalyst express 500, i need disable switchport port-security, a try with http://10.1.1.1/exec and save configuration with wr command, if a check the configuration de port is correct but i reboot the switch and check the configuration the port appear the switchport port-security configuration again.
do you know solve this??
thk and regards!!!
