Bypassing Windows Remote Dial-in configuration
Sep 2nd, 2007
I am in the process of configuring proxy authentication on a Cisco ASA firewall whereby users trying to access the internet have to log in using Cisco ACS radius services and Active Directory.
The challenge I am having is that on the AD I have to enable remote dial in for every user. Now, the users are quite many and I will take a long time to finish. Is there a way of bypassing remote dial in configuration on both the ACS and Active Directory?
Thanks.
andrew.brazier@... Wed, 09/05/2007 - 02:18
  • Bronze, 100 points or more
Go to the external database configuration and select the Windows Database. Modify your Windows DB and one of the tick boxes will be something like "reference Windows Dial-up settings". Untick it and save.
