E1 call setup fail
Sep 2nd, 2007
Hello I am configuring a new gateway with an e1 pri to the pstn. And when I try to make a new call i received the following error:
"ZAVGW001#
*Aug 31 11:38:19.079: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0181, '153'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '944056536'
Plan:Unknown, Type:Unknown
*Aug 31 11:38:19.143: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8001
Cause i = 0x82E404 - Invalid information element contents"
The call flow is "cp7941" --> "ccm5.1" --> 2821 gw E1 backhaul --> pstn
pklos Mon, 09/03/2007 - 08:19
  • Silver, 250 points or more
Did you try to transform "calling party number" from '153' to 9 digit number? You can do this by using external phone number mask or prefix digits on gateway configuration.
regards,
pk
fjrubiobarcena Tue, 09/04/2007 - 07:22
Hello this is the output of a bad outgoing call and of a good incoming call
ZAVGW001#
*Sep 4 15:11:47.847: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Sending Complete
Standard = CCITT
Calling Party Number i = 0x0181, '976749399'
*Sep 4 15:11:47.899: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8001
ZAVGW001#
ZAVGW001#
ZAVGW001#
*Sep 4 15:12:15.995: ISDN Se0/0/1:15 Q931: RX <- SETUP pd = 8 callref = 0x0007
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Channel ID i = 0xA18387
Preferred, Channel 7
Calling Party Number i = 0x0183, '647807006'
Called Party Number i = 0xA1, '976749399'
Plan:ISDN, Type:National
*Sep 4 15:12:16.011: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8007
Channel ID i = 0xA98387
Exclusive, Channel 7
*Sep 4 15:12:16.015: ISDN Se0/0/1:15 Q931: TX -> ALERTING pd = 8 callref = 0x8007
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Sep 4 15:12:17.407: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0007
Cause i = 0x8090 - Normal call clearing
*Sep 4 15:12:17.423: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8 callref = 0x8007
*Sep 4 15:12:17.447: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0007
ZAVGW001#
Thanks for your help
paolo bevilacqua Tue, 09/04/2007 - 07:57
  • Hall of Fame,
    Founding Member
It coulbe that telco wants type/plan ISDN/national. Are you using h.323 or MGCP, try setting that.
