incoming calls without the 0 occuring from pri provider
Sep 2nd, 2007
We have call manager express 3.3 with a e1 pri module.
if i ring the main number over the pri then my number appears without the 0. The provider is saying this is how they present it. Is there a way of inserting a 0 in front of the incoming number. Also, we use 9 for outside line. therefore i would also like to insert a 9 before this 0 so when i go to missed calls i can just call them from the missed calls in the phone without having to note the number and insert the 9 and then the 0 myself.
any ideas?
Try this, use a voice translation rule and a translation profile to do this. In the UK, I do it with the following commands. Note the use of the ISDN numbering plan parameters, that will prefix 90 to a local/national call and if the incoming call is international, it will prefix 900 (this is for UK plans, but you can see the concept). The you just apply the profile to the voice port for incoming calls. Tha translation profile is set to translate the calling party.
voice translation-rule 1
rule 1 /^\(\)/ /900\1/ type international international
rule 2 /^\(\)/ /90\1/ type any national
voice translation-profile Prefix-90
translate calling 1
voice-port x/x
translation-profile incoming Prefix-90
cmelbourne Mon, 09/03/2007 - 05:48
Bill,
Thanks for this, This makes sense.
I will try this and see how happens.
the voice-port x/x i take it i just change it to the signalling channel of the controller e1, is this right?
paolo bevilacqua Mon, 09/03/2007 - 09:59
  • Hall of Fame,
    Founding Member
Indeed, a small nitpick, the rule above can also be written more concisely as:
rule 1 // /00/ type international international
rule 2 // /0/ type any national
This assumes you are not using any prefix digits for outgoing calls, thing that I've found very convenient an liked by my customers.
