We have two AS5400XM (R1 and R2) and there is no and DFC, no ISDN PRI. How do we config the voip to voip? I search cisco and cannot find out the config. Could you give me some idea? following is the dial peer we create. does it work? how do we config the "inbound voip" for AS5400XM? please advise thanks
R1
! send out voip to R2
inter gi 0/0
ip address 192.168.10.1 255.255.255.0
dial-peer voice 1 voip
! destination-pattern 86
session target ipv4:192.168.10.2
dtmf-relay rtp-nte digit-drop h245-signal h245-alphanumeric
fax rate 9600
R2
! send out voip to another as54 with ISDN PRI
inter gi 0/0
ip address 192.168.10.2 255.255.255.0
dial-peer voice 2 voip
session target ipv4:192.168.10.35
fax rate 9600
R3
inter fast e
192.168.10.35 255.255.255.0
! as5400 with isdn pri
dial-peer voice 3 pots
application session
direct-inward-dial
port 7/7:D
Best regards
