Simple question on Subnetting
Answered Question
Sep 3rd, 2007
Greetings!!
If I have a /30 subnet, say x.x.x.0/30, I will use .1 & .2 and cannot use .0 since it is subnet and .3 cannot be used since it is a broadcast ip address.
But, instead, if I further subnet the /30 to /32, I will get four ip addresses, .1, .2,.3,.4/32; can I use all of them for four different loopbacks on four different L3 interfaces?
Thanks in advace :-)
Correct Answer by mohammedmahmoud about 9 years 5 months ago
I think that Arivudainambi's answer covers your question, just to elaborate more, we can also use a /31 prefixes, in order to conserve IP address space on the Internet, a 31-bit prefix length (255.255.255.254) allows the use of only two IP addresses on a point-to-point link. Previously, customers had to use four IP addresses or unnumbered interfaces for point-to-point links.
IP directed broadcast not allowed with 31 bit mask (when entering a /31 address ip directed broadcast will be immediately disabled).
NOTE no ip directed-broadcast is the default on modern IOS and thus it might not appear in the configuration.
When entered on a non point-to-point interfaces the following error occurs: % Warning: use /31 mask on non point-to-point interface cautiously.
http://cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455093.html
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
nambi_gct Mon, 09/03/2007 - 03:55
Yes.It is valid.With /32 mask, logically broadcast address,subnet address and the host address are the same./32 is the recommended mask for loopback interfaces.
Correct Answer
mohammedmahmoud Mon, 09/03/2007 - 04:12
HTH,
Mohammed Mahmoud.
rkunta Mon, 09/03/2007 - 04:19
Thank you Mahmoud, that really helps....
Ramchander.
mohammedmahmoud Mon, 09/03/2007 - 04:32
Hi Ramchander,
You are very welcomed, and thank you for using the rating system.
BR,
Mohammed Mahmoud.
rkunta Mon, 09/03/2007 - 04:39
You are welcome Mahmoud, one more quick question. In case of /31, how do I address the subnet? There are only two ip addresses possible here, but how do I address the subnet? (or will there be no necessity of using subet? I am not able to comprehend!)
mohammedmahmoud Mon, 09/03/2007 - 06:06
Hi Ramchander,
It is just used for point-to-point links, where only one end is trying to communicate with the other end.
HTH,
Mohammed Mahmoud.
chintan-shah Tue, 07/29/2008 - 01:34
Hi Mohammed,
I am planning to use /31 and I tested that it works fine. But I wonder in one my ACL what should be wildcard i use ? 0.0.0.1 for /31 or soemthing else ?
chintan.
