Help with MGCP Config. Unable to recieve calls
MARTIN STREULE Mon, 09/03/2007 - 05:39
If you can do outbound calls, the config on the gateway cannot be that bad. :-)
Do you have a proper CSS configured in the CCM configuration of the gateway?
Is the number of digits you receive okay and adjusted in the config?
pklos Mon, 09/03/2007 - 08:16
Maybe you have no "external phone number mask", so outgoing call works fine, but incoming won't match internal extension?
