Why ssh does not work?
Answered Question
Sep 3rd, 2007
I do not know why I can not login using ssh client to my router... here is my configuration.
Best regards and thks
Correct Answer by shahzad-ali about 9 years 6 months ago
Try "login local" under vty.
line vty 0 4
access-class 102 in
password 7 xxxxx
login local
-Shahzad
Overall Rating: 5 (1 ratings)
edgar-quintana Tue, 08/28/2007 - 18:40
The new configuration is:
line con 0
line aux 0
line vty 0 4
access-class 102 in
password 7 xxxxx
login
transport input ssh
transport output none
Edison Ortiz Mon, 09/03/2007 - 07:35
  • Hall of Fame,
    Founding Member
Can you remove the access-class ?
Perhaps the ACL is blocking your session.
edgar-quintana Mon, 09/03/2007 - 07:37
This acl permits me to connect to, if I delete this acl I can not connect
Correct Answer
shahzad-ali Mon, 09/03/2007 - 08:23
line vty 0 4
access-class 102 in
password 7 xxxxx
login local
-Shahzad
edgar-quintana Mon, 09/03/2007 - 08:42
Was login "local" command which resolved my issue.
Thks a lot..
Best regards
jsmitty10 Mon, 09/03/2007 - 06:05
Edgar I apologize,Edison's link is much better sorry for the confusion!
Edison Ortiz Mon, 09/03/2007 - 07:04
  • Hall of Fame,
    Founding Member
1) Try another client such as putty or secure-crt.
2) enable login under the vty lines.
