LMS 2.6 DFM Suspending Device Component
Sep 3rd, 2007
After I suspend a device component (ex. Interface of a router), does it possible to see a list of devices with suspended component?
I like to remove recurrents low priority alarms.
Best Regards
Joe Clarke Mon, 09/03/2007 - 08:28
I'm assuming you mean you unmanaged components in the Detailed Device View. If so, then there is no way to get a list of devices that have components with a management state of false.
acalligher Mon, 09/03/2007 - 12:30
Exactly, so in this case maybe it better to place in suspend state the device.
I will avoid to forget the unmanaged components.
Joe Clarke Mon, 09/03/2007 - 12:57
You can also create views that only filter on the devices you care about (under DFM > Configuration > Other Configurations > Alerts and Activities Defaults). This way, you can still manage the devices, but cut down the unwanted alerts in AAD.
