NIC teaming (NFT) failover time
Sep 3rd, 2007
  • Silver, 250 points or more
How much time does it take a server attach to two swith using hp NFT to detect a link failure on the primary link.
Let's say the link failure is cause by power been removed from the first swith
ebreniz Fri, 09/07/2007 - 13:56
I think if you disable NIC teaming then SQL and Unity start correctly. Checked NIC teaming configuration and they are identically configured except the version is different.
