Explanation required for the secondary address behavior
ambi
I just tried pinging to the broadcast address of a subnet to see how many hosts reply to it.
I saw some replies from IPs that were other the subnet. when i checked the L3 configuration i saw a secondary address associated with the interface but i am unable to understand the behavior
router#p 172.16.56.255
Sending 5, 100-byte ICMP Echos to 172.16.56.255, timeout is 2 seconds:
Reply to request 0 from 172.16.56.2, 8 ms
Reply to request 0 from 144.12.16.208, 8 ms
Reply to request 0 from 144.12.16.14, 8 ms
Reply to request 0 from 172.16.56.4, 8 ms
Reply to request 0 from 172.16.56.3, 8 ms
Reply to request 0 from 144.12.16.3, 8 ms
Reply to request 1 from 144.12.16.208, 4 ms
Reply to request 1 from 144.12.16.14, 4 ms
Reply to request 1 from 172.16.56.4, 4 ms
Reply to request 1 from 172.16.56.6, 4 ms
Reply to request 1 from 172.16.56.3, 4 ms
Reply to request 1 from 144.12.16.3, 4 ms
layer 3#sh run int vlan 1
Building configuration...
Current configuration : 222 bytes
interface Vlan1
ip address 172.16.56.5 255.255.255.0 secondary
ip address 144.12.16.14 255.255.255.0
no ip redirects
no ip unreachables
end
thanks in advance
Edison Ortiz
They may be different IP subnets but they are both in the same broadcast domain (Vlan1).
If you take a packet trace, you will see the destination MAC for 172.16.56.255 is ff:ff:ff:ff:ff:ff
All hosts within that broadcast domain will process that packet.
