Is TAB key available during CCNA exam?
Sep 3rd, 2007
Also is the question mark available eg.
show ?
My guess would be NO to both questions.
How can I find out about what devices I will be tested on and what IOS version they will be running ? (for switches and routers).. Thanks
1 vote
scottmac Mon, 09/03/2007 - 10:44
Both the question mark and the tab key are available.
Be advised though that you will get some options on the question mark that are not valid; you still have to know what the correct command should be.
The other thing with the question mark is that you will only get some of the options. If you hit the question mark intending to do something one way, and you don't see the option you expected, then that's not what Cisco had in mind for the solution.
I'm pretty sure they are still doing 12.3, it's posted in the CCNA study area somewhere.
Good Luck
