Loop on atm interface
Sep 3rd, 2007
Hi all
1. If I place a loop on a router by configuring loopback line at the interface config at the router. What problem am i trying to isolate. ? Where is it looping from ?
2. May i know what type of interface can i create a software loop on.
3. Can i create a soft loop on a serial interface using IOS command ?
Hope someone can help. Thanks in advance
Alan
paolo bevilacqua Mon, 09/03/2007 - 15:09
  • Hall of Fame,
    Founding Member
1. actually, not much. You are just proving that the looping hardware at the interface is working as expected and this happens in 99.9% of the times.
2. mainly T1 and E1, and some type of serial interface.
3. see above, configure either at controller or interface level.
purohit_810 Mon, 09/03/2007 - 18:28
  • Silver, 250 points or more
You can do soft loop by using modem DIP switch settings.
As of your que. Answer you can use LOOPBACK command under interface configuration mode..
But you need to really understand to other parameter also and debug commands also. so, you can analyze proper problem area.
You can see on this URL for different Loop back commands
http://www.cisco.com/en/US/docs/ios/12_0/interface/command/reference/irinterf.html
Dharmesh Purohit
