09-03-2007 03:51 PM - edited 03-11-2019 04:05 AM
I have a new ASA 5505 and I'm configuring it using the ASDM 5.2 client. The firewall is running in transparent mode. I was able to add some Access Rules, but I am having trouble trying to delete them.
I get messages like this:
[ERROR] no access-list IN line 3 extended permit object-group tcp-udp 0.0.0.0 0.0.0.0 object-group internal
Specified access-list does not exist at that line
Some rules I can create and then delete, others I get similar error messages.
Can anyone help? Thanks!
09-07-2007 02:00 PM
Your problem is similar to the one described in Cisco bug CSCse86318. You should upgarde to ASDM ver 5.2(2.0) or later for the fix of this issue.
09-07-2007 02:37 PM
If it's not because of any bug, did you try removing the access-list without specifying the line no.? If not, we can try that as well.
