Unity Design Query: Same extension in different Partition
Sep 3rd, 2007
I have a query where I have 2 remote sites with the same extension range:
Site A: 1231000 to 1231999
Site B: 7891000 to 7891999
I think there is two ways to do it, first in CCM and unity, to use 7 digit extensions. The VM and MWI should work.
But I'm thinking can we leave the CCM as 4 digit extensions and use the two seperate VM profile's mask as 123XXXX and 789XXXX. I am able to leave a VM to the correct mailbox, but the MWI doesn't work.
I think the VM port must be able to reach both Site A and Site B phone partition, but the CSS is sorted in order, therefore it would never reach Site B partition.
Did I missed out something? Have anyone tried this before?
Thanks!
Eugene
Overall Rating: 4 (2 ratings)
eug-c Wed, 09/05/2007 - 01:36
*Bump
Anyone has any experiences using Unity between 2 sites with similar extensions?
Eugene
shane.orr Fri, 09/07/2007 - 08:26
  • Silver, 250 points or more
Your concerns are very valid. Take a look at the following:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dde5bc3/0
I have heard rumors that a future Unity release will be Partition and Calling Search Space aware which will alleviate this kind of problem.
eug-c Wed, 10/03/2007 - 21:30
Thanks guys.
Hope the new release would solve this issue alright.
Eugene
