Need help on deciding the part number for cisco fan tray
Sep 3rd, 2007
I have a switch with part number WS-C4006-S2 , and the fan tray for this switch is faulty, however,i do not know the part number for the fan tray, furthermore, i have found one fan tray's part number in cisco website, WS-X4005= with description :Catalyst 4006 Fan Tray (Spare);my question is i would like know whether WS-X4005= is the correct fan tray for WS-C4006-S2 .
Edison Ortiz Fri, 09/07/2007 - 14:40
  • Hall of Fame,
    Founding Member
Yes, that fan will meet your needs.
HTH,
