AAA authentication from ACS
iqbalkhan
HI
In my router I am configure AAA authentication default login and default enable password from ACS. so when I login my router then login password and enable password come from ACS. I am also configured login default local.
my problem is if ACS down or unavailable then time i can not access router becuse enbale password is configure default in ACS. so have any way that if acs is down then time take enable password fromlocal.
thanks
Biplob
dominic.caron
Level 5
Level 5
Do something like this
aaa authentication login default group tacacs+ line
aaa authentication enable default group tacacs+ enable
First the router will try ACS and if not there, the localy configure password.
arififtikhar
Is your problem still there?
Just create a (netadmin) username and level 7 password on the router and your problem will be over.
Arif
srivastava_s
hi
You can use lable 7 password and username
and ure enable password in this time
saurabh
thanks to all.it is now solved
